1994 Pontiac Bonneville water in oil
1994 PONTIAC BONNEVILLE
167,000 MILES • 6 CYL • FWD • AUTOMATIC
ZIMMIE
  • 7 POSTS
I have a 1994 Pontiac Bonneville with a 3.8 liter 3800 V6 with 165,000 miles. I bought it "as is". With all the options and they all work. It didn't have water in the oil when I checked it the day I bought it. But I had to replace the water pump,and the thermostat. Not a good sign I know, I started it and now I have water in the oil. I didn't run it long. I changed the oil and again full of water.. How do I check for blown head gasket or intake what ever it could be ? Thanks for any help.
Dec 25, 2007 at 9:04 AM
  • 31,937 POSTS
Hi there,
Check spark plugs, if one is a dirty drown colour, that will be water in the cylinder. There are chemical tests that check for Co in the water, Excessive bubbles in the radiator are also a fair indication as well.
Mark (mhpautos)
Dec 25, 2007 at 8:53 PM
ZIMMIE
  • 7 POSTS
Hi Mark
I'll check my spark plugs and let you know what I find ? I know the coolant is ending up in my oil pan if that helps you any. Thanks again.
Dec 25, 2007 at 11:45 PM
  • 31,937 POSTS
Hi there,
Time to pull the heads i think, If it is not miss firing or to rough in the idle, just have a really good look at the Vally cover (intake manifold) for corrosion and or cracks around water transfer ports, you may be lucky.
Mark (mhpautos)
Dec 26, 2007 at 7:03 AM
ZIMMIE
  • 7 POSTS
Thanks Mark, I guess I'll start with the intake, It would be nice if it was that and not much damage. I'll keep you posted, thanks again, Zimmie.
Dec 26, 2007 at 7:43 AM
