1994 Pontiac Bonneville compressor wont kick on
1994 PONTIAC BONNEVILLE
560FARMALLM1947
Air Conditioning problem
1994 Pontiac Bonneville 6 cyl Two Wheel Drive Automatic
i am working on a 1994 bonnevile and need a wiring diagram, it has power at the relay but the clutch wont kick in if i had a diagram i could figure it ouit
Jun 5, 2010 at 9:02 AM
You sure it has the correct amount of freon if so power the magnetic clutch from the battery and see if it engages the compressor
Jun 5, 2010 at 11:04 AM
