1994 Pontiac Bonneville Battery issues
1994 PONTIAC BONNEVILLE
197,526 MILES • 6 CYL • FWD • AUTOMATIC
ELIZAFAIRY97
The car has recently had a new starter, alternator and battery cables and new battery. Since the new battery has been installed the gauge will read full battery. Then within the last week as soon as I shut off the car even tho the battery gauge says that it's full, when I go to start it again I end up needing a jump start. Sometimes the battery will shift as well and not be connected at all. Still after making sure it's in place, it needs a jump start after shutting it off every time. We have looked and theirs nothing that gets left on to drain it. Thank you
Aug 31, 2010 at 2:03 PM
LEGITIMATE007
  • 5,121 POSTS
you may just have a connection problem, check all connections and clean the terminals. and check all connections from the battery to the alternator to the starter.
Aug 31, 2010 at 2:40 PM
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
ELIZAFAIRY97
Thank you Legitamate007 will do and then will post on here. It's been pouring down rain here so hopefully it will be somewhat nice tomorrow.
Aug 31, 2010 at 2:55 PM
LEGITIMATE007
  • 5,121 POSTS
ok, good, keep me posted
Sep 1, 2010 at 3:19 AM
