1994 Pontiac Bonneville
1994 PONTIAC BONNEVILLE
162,000 MILES • 6 CYL • FWD • AUTOMATIC
ARTHURRIDEAUX
WHAT CAUSES MY CAR TO HESITATE AT A STOP AND AFTER DRIVING FOR A WHILE THE CATALYTIC CONVERTER BE RED HOT.
Jun 2, 2010 at 2:38 PM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 4, 2010 at 12:23 AM
