1994 Pontiac Bonneville
1994 PONTIAC BONNEVILLE
SLATER69
fuel pump is not working been replaced,all fuses are good what else could be the problem
Mar 24, 2009 at 2:17 AM
JDL
  • 16,098 POSTS
Hello, have you tried running the pump by using the prime connector? That connector may be located behind/by the battery. Red wire, electrical connector, nothing plugged into the connector. If you use an inline fuse, jumper to B+, the pump should run.
You could check the fuel pump relay circuits. That relay center may be under the dash, passenger side. There should be a 20 amp fuse by that relay center for the pump relay.
Any codes?
Mar 24, 2009 at 4:47 AM
