1993 Pontiac Bonneville speedometer
1993 PONTIAC BONNEVILLE
THOMPSON001
  • 10 POSTS
Electrical problem
1993 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
i have 93 bonneville with dual speedometers. 1 in inst cluster and projection on windshield. was working fine now 10 mph difference between the 2. projector shows 10 mph faster than 1 in inst cluster. inst cluster speedo is accurate. what could cause this and is there a way to reset or recalibrate projector to match inst cluster speedo. verry irritating and confusing when see wrong speed on window all the time. can u help?
Nov 21, 2009 at 4:36 PM
RACEFAN966
  • 5,029 POSTS
Ok first off no reset or calibration for the heads up display module. There is little to no info on this early system. However there is a heads up display control module behind the instrument cluster.
Nov 24, 2009 at 2:00 AM
