1993 Pontiac Bonneville Refuses to Idle
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
THEFEAR6
My car is having an issue idling. At first I thought it might be the battery or some other electrical issue but I can't manage to figure the issue out. I can only manage to get the engine to turn over upon giving it gas and keeping my foot on the gas to keep the engine idling. I attempted to let up on the gas from after having let it run for about 10mins and it would stall immediately. I believe it to be the Idle Air control motor but it seems to be functioning properly. Currently I am about out of ideas with the many issues that could be originating from the throttle body and simply am about to give up.
Dec 27, 2009 at 8:07 AM
  • 75,988 POSTS
Clean out the idle air control valve and the EGR valve then test the throttle position and manifold absolute pressure sensor
Dec 27, 2009 at 8:56 AM
