1993 Pontiac Bonneville oil pressure gage
SHAWNCOLE2372
  • 1993 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 229,000 MILES
My oil pressure keeps going up when I accelerate. The oil level is good it is exactly on the line.
Saturday, July 31st, 2010 AT 8:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Oil pressure is supposed to go up slighty when accelerating.
Is oil pressure going into High / Red zone?
Saturday, July 31st, 2010 AT 8:08 PM
SHAWNCOLE2372
  • 5 POSTS
It goes up over 120 psi or all the way to the red
Saturday, July 31st, 2010 AT 8:10 PM
SHAWNCOLE2372
  • 5 POSTS
It goes up over 120 psi or all the way to the red.
Saturday, July 31st, 2010 AT 8:12 PM
SHAWNCOLE2372
  • 5 POSTS
Saturday, July 31st, 2010 AT 8:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Ok ince it is going high but oil level is not over or under you will need to test the oil pressure with a mechanical gauge to ensure the in-car gauge is accurate. If it is accurate then the oil may be too thin (wrong vescosity) or worn out, or the oil pump may need replaced.
Saturday, July 31st, 2010 AT 8:22 PM
SHAWNCOLE2372
  • 5 POSTS
Thank you for the answer I will do that.
Saturday, July 31st, 2010 AT 8:25 PM
