1993 Pontiac Bonneville Coolant smell
1993 PONTIAC BONNEVILLE
PATSBEER
Heater problem
1993 Pontiac Bonneville 6 cyl Front Wheel Drive 171000 miles
As the engine warms up. I start to smell antifreeze coming though the heater. I can smell it outside but when the car reaches temp the smell disappears. I haven't seen any leaks or contamination of the oil. Can you tell me what could be causing this?
Thanks
Dec 8, 2008 at 12:00 AM
  • 110,240 POSTS
Hi:
If you smell it in the vents, it is most likely the heater core. Do you ever get a fogging on the windshield that is hard to defrost?
Dec 14, 2008 at 4:09 AM
PATSBEER
They're no fogging. Like I said there's an antifreeze smell. But once the car warms up that goes away. The heater core does sound like a probable problem.
Thanks.
Dec 14, 2008 at 5:38 AM
