1993 Pontiac Bonneville
1993 PONTIAC BONNEVILLE
136,000 MILES • 6 CYL • FWD • AUTOMATIC
JERRY PACE
car idles ok,fuel pressure ok,apply brakes to stop and car dies!!
Feb 24, 2008 at 11:13 PM
MERLIN2021
  • 17,250 POSTS
You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs!
Also check for codes, is the service engine light on?
Feb 24, 2008 at 11:22 PM
