1992 Pontiac Bonneville Turn & Hazard Signals
1992 PONTIAC BONNEVILLE
207,000 MILES • 6 CYL • 2WD • AUTOMATIC
SCOTT3000
Turn Signals and Hazards work, but the intervals have really slowed down. I was wondering if this is a fuse or Flasher-Relay problem?
Sep 25, 2009 at 10:41 AM
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle uses separate relays for the hazard and turn signal flashers. if both are doing the same then it is most likely not the relays. may want to have your charging system tested out .
Sep 25, 2009 at 11:51 AM
