1992 Pontiac Bonneville ignition problem
JIK747
1992 Pontiac Bonneville 6 cyl Two Wheel Drive
my 92 pontiac bonneville recently died while i was driving it then it wouldn't start. i checked to see if there was spark at the coil packs, there wasn't. i took off the coil packs and i have power to the prongs on the ignition module. does this mean that the ignition module is good and i need to check something else or is it possible that ignition module is bad.
Nov 7, 2009 at 6:50 AM
COMPG
jus cuz u had power at the icm leads doesnt mean its working right. it could still be malfunctioning. but another thing to check is the long wiring plug comming from the bottom of the icm cuz i've seen those wear out and need to be replaced.
could be many other things tho.
does it crank over or do nothing when u turn the key?
if it rolls over does it fire on any cylinders or none?
is this an innermitant prob or will it never start?
Nov 22, 2009 at 4:31 PM
