1992 Pontiac Bonneville A constant beep
1992 PONTIAC BONNEVILLE
BONNEVILLE129
Noises problem
1992 Pontiac Bonneville 6 cyl Automatic 260000 miles
the gauges for battery, oil are fine it is not overheating.
it starts beeping whenever i accelerate. Beep beep beep beep beep. etc. it's pretty annoying.
check engine light is on but the car runs on the freeway fine. any ideas on what is wrong?
The noise used to be intermittent but now it beeps on almost all the time when i accelerate. it sounds like the sound when you leave the key in the ignition when you open the driver's door but it is more continuous (less time between beeps)
I want the noise to stop. I am trying to avoid taking it to a mechanic.
Apr 19, 2009 at 2:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
First off I would like to apologize for the wait..
Since your engine light is illuminated you should first get the trouble codes retrieved. Most local part stores will do this free of charge. Post your codes retrieved and we can begin troubleshooting much quicker this way.
Is there any anti-theft devices on this vehicle or any unusual lights being illuminated when the beeping occurs?
Thanks for using 2CarPros.com!
Apr 21, 2009 at 11:42 AM
