speedometer
1991 PONTIAC BONNEVILLE
184,000 MILES • 6 CYL • FWD • AUTOMATIC
GNEWT270
Speedometer and odometer stopped working.What is the most common problem?
Sep 13, 2009 at 8:04 AM
DOCFIXIT
  • 18,828 POSTS
The vehicle speed sensor on trans axle on the passengers side. Here is a diagram to help you see where it is. Check the fuses first.
Check out the diagrams (Below)
Please let us know what you find.
Cheers
Sep 13, 2009 at 8:21 AM
JDL
  • 16,098 POSTS
I'd check the vss, my info says top rear of transaxle, probably two wire connector, wire colors purple and yellow. Some makes and models, I can find it by removing the passenger side tire. Not sure about your model, my database wasn't exact about the location.
Sep 13, 2009 at 8:24 AM
GNEWT270
I had to change the cluster out everything working now.
Sep 27, 2009 at 12:32 AM
MMPRINCE4000
  • 8,548 POSTS
The gauges themselves go bad.
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers
Sep 27, 2009 at 1:01 AM
