1990 Pontiac Bonneville oil leak
1990 PONTIAC BONNEVILLE
205,000 MILES • 6 CYL • FWD • AUTOMATIC
GENO M
My wife got home from the store and after the car sat not running for just a few mins I noiticed a puddle of oil under the passanger side (the front of the engine) there is a lot of oil coating the front of the engine and I can not tell where the oil leak is. I do it is not comeing from the value covers, the oil is below them by a couple of inches on both sides. Is there a gasket or seal that might be leaking? Thanks for any and all help.
Apr 3, 2010 at 10:38 AM
MMPRINCE4000
  • 8,548 POSTS
Most likely the front main seal, you will have to remove the balancer to get to it.
Apr 4, 2010 at 12:34 AM
