1990 Pontiac Bonneville Fuel Injector problem
1990 PONTIAC BONNEVILLE
BXROBI01
Electrical problem
1990 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic unknow miles
The first fuel injector in the gas line (back right) doesn't work most of the time, but sometime does. By using a noid (sp?) light my friend discovered that the problem was electrical and not the fuel injector itself. The only problem is, we don't know what it is. My friend believes that its the pigtail, but im skeptical. I don't want to spend the time and money relacing it if its not going to work.
May 22, 2008 at 5:19 PM
BLACKOP555
  • 10,386 POSTS
since there is no pulse on that injector and its the only one that is acting up i would suspect a short in the wiring or a problem with the pigtail connector as your friend states.
May 23, 2008 at 2:40 AM
