1990 Pontiac Bonneville Cruise control Module
1990 PONTIAC BONNEVILLE
75,000 MILES • 6 CYL • FWD • AUTOMATIC
BOOMER107
Hello Guys
Ok I have a 1990 Bonneville SSE and just got a new Cardone 34-1874 cruise control module. I have a Chilton repair manual for the car, but for the life of me I cannot find it on the car. I loked under the dash on the drivers side and behind the glove box on the passenger side, but i can't see it. Is their a place that I'm not looking?
The reason I'm replacing the module is that the cruise when set will kick out by itself. I can turn it off and reset it but a few miles down the road it does the same thing. All vacume lines appear to be good as I checked for leaks and bad hoses but found none.
Any help with this would be greatly appreciated.
Thank youi in advance
Dan
Sep 21, 2008 at 2:53 AM
The CCM is located on left side of dash left of steering column
Sep 21, 2008 at 3:01 AM
BOOMER107
Found the module. It was higher up in under the dash then I expected. I replaced and just test driven the car and all is working fine so far. Thanks again for your help. I have you guys booked marked.
Dan
Sep 21, 2008 at 7:08 AM
