1989 Pontiac Bonneville wont start after running for a bit
60,000 MILES • 6 CYL • FWD • AUTOMATIC
LMOYER03
my car will not start after i have drove it, so i been having to let it cool down before i can start it, could it be the ignition module, aus ei put a junk yard one on to replace it and it did not work
Apr 26, 2009 at 1:26 PM
  • 75,988 POSTS
Don't wait do below immediately to catch what's causing it.
Get helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Apr 26, 2009 at 11:34 PM
