I was checking switching out the Electronic ignition module that fit under the coil pack & heard something arch (i touch something with the wire) after checking i notice i left the key on! yes, I'm a Dummy but my problem is now it won't start even if i put the old module back on??? is there fuse that i miss i check #17 in the fuse box. Now my original problem was the car will die out at idle or when driving and come to a stop or just take my foot off the gas pedal. service engine been on for years! had it reasonably check code 41 switch out crank shaft sensor still no luck that bring to the electronic control module. can you help??? Tony
Sep 15, 2010 at 12:58 AM
