1989 Pontiac Bonneville Driver Side Seat Belt Replacement -
125,428 MILES • 6 CYL • 2WD • AUTOMATIC
WEBE0122
'89 Bonneville LE - Need to replace driver side seat belt,
won't recoil slack any longer.
1) Any recommendations on replacement seat belts for the bonneville? (Note: Dealer parts department told me OE is no longer available.)
2) The top mount is in the upper corner of the window/door frame? How do I remove that mount, there does not appear to be any exposed screws/bolts?
Thank you!
Oct 2, 2009 at 9:33 AM
MERLIN2021
  • 17,250 POSTS
Chances are you need to find a good used one, Junkyards or maybe ebay. Plastic cover on the top mount is just pulled off to expose the fastener.
Oct 3, 2009 at 1:10 AM
