1988 Pontiac Bonneville Driver Info Window
1988 PONTIAC BONNEVILLE
105,000 MILES • 6 CYL • FWD • AUTOMATIC
HAVOZZ
Hello, I have a Pontiac Bonneville 1988 SSE in very good conditions, a wile back the driver info window turned off and from time to time comes back on, every time I press the break it goes off or the light decreases dramatically, when the brake its released again, the light comes back on with intensity, but form time to time goes of for no reason, I took it to a very dishonest dealer and say that the car its so old that the dash board inside its falling apart, but as a fact I know that's not the case because I open it once and it looks brand new, what can be the problem?
Jun 14, 2009 at 6:02 AM
MIKE H R
  • 3,094 POSTS
check for wires around the break pedal, A wire could be grounding out when the pedal is pushed. with the wire being bare it could ground out with just hitting a bump. also check any grounds wire you see.
Jun 14, 2009 at 1:55 PM
