1987 Pontiac Bonneville leaking at freeze plug
1987 PONTIAC BONNEVILLE
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
MICKCORRIGAN
My 1987 Pontiac Bonneville has a leak at a freeze plug. Is this a hard thing to fix? Will radiator stop leak and conditioner temporailly fix this problem? I can't even fill the radiator with fluid because it comes right out the freeze plug. Help!
Apr 17, 2010 at 7:56 AM
You need to replace the freeze plug-you can drive it out with a screwdriver or use a dent puller/slide hammer
Apr 17, 2010 at 8:36 AM
MICKCORRIGAN
thnx rasmatz.. it looks complicated to get to.. it's the front freeze plug.. does the engine need to be lifted to get to it?
Apr 17, 2010 at 9:24 AM
