1968 Pontiac Bonneville charging system question
99,999 MILES • V8 • 2WD • AUTOMATIC
TATOOWEENY
  • 5 POSTS
[img:4cc26e1cd8]http://www.2carpros.com/forum/automotive_pictures/266701_266701_1968_Pontiac_Bonneville_01_1_3.jpg[/img:4cc26e1cd8]
I recently replaced the battery, alternator, and voltage regulator hoping it would solve my problem... It hasn't. When I start the car, every light inside and out (when turned on) pulsates. The battery is not charging. but so far the car turns over fine. I thought it could be the ground strap to the engine, but it's connected. I also cleaned the terminals to the battery & checked the cables/wires where I could throughout the system. Nothing seems to be burn't or frayed. I'm sure it's something simple, right? Please help! -Jake
Nov 27, 2008 at 8:55 AM
  • 75,988 POSTS
Check the voltage regulator its job is to regulate the alternator output voltages-double check all connections. Try full fielding the alternator-if it charges the battery-replace the regulator
Nov 27, 2008 at 9:03 AM
