1963 Pontiac Bonneville
95,000 MILES • V8 • 2WD • AUTOMATIC
MAGNAMANV45
  • 5 POSTS
I need to remove the harmonic balancer on a 389 engine. which way does the bolt turn on the crank to loosen it? and how do I stop the engine from turning to remove the bolt?
May 19, 2009 at 6:05 PM
  • 75,988 POSTS
Counter clockwise-either you remove the flywheel inspection plate and jam the flywheel with a long screwdiver or use a cheater bar on the crank pulley and crank engine over-
May 19, 2009 at 6:32 PM
MAGNAMANV45
  • 5 POSTS
thank you very much, and I will tell all my friends what a help your are.
May 19, 2009 at 8:20 PM
