1961 Pontiac Bonneville Oil Leak
15,500 MILES • V8 • 2WD • AUTOMATIC
BOBPAT1595
I have a low milage 1961 Pontiac Bonneville and the rear main seal is starting to leak oil. Is their a product out there that may cure my leak without going through the work of replacing the gasket?
Thanks.
Nov 27, 2009 at 5:59 AM
  • 110,248 POSTS
Wow! That is low mileage. Yes there are products that are designed to swell the seals and gaskets. If you stop at a parts store, explaine what the problem is and I'm sure they will have something for you. However, a 61 with 15K on it may be worth repairing properly.
Let me know what you find and if it works.
Dec 16, 2009 at 12:11 AM
