water intake leaks
ILV2HNT
2001 aztek has 80,000 miles and the water intake leaks and i'm trying to figure out what this all intales and should cost to repair
Jul 20, 2007 at 1:29 PM
CLY
  • 308 POSTS
The upper and lower intake gaskets need to be replaced,Also the valvecover gasets, and a few misc o-rings. It is a good idea to replace the oil pump drive seal while the job is being preformed as it is right there and known to leak...probably looking at about $700.00 to complete the repair....It is about a 6 hour job as far as labor goes....
If it is leaking I would not drive it anymore than you have to because those are known to leak internaly as well and coolant is hard on bearings........
Cly
Jul 20, 2007 at 1:41 PM
