2004 Pontiac Aztek Serpentine Belt
103,000 MILES • 6 CYL • 2WD • AUTOMATIC
MHOUGH
How do you change the serpentine belt?
Jul 15, 2009 at 10:11 AM
TROY LEPPERT
  • 12 POSTS
Now i cant be sure onthis but i checked my 01. there is a bolt on the altanater that allows it to loosen then if you feel behind the altanater there is another bolt and my guess would be that that is a tension bolt if you loosen those you should get enough slack to change out your belt. good luck
Sep 2, 2009 at 12:47 PM
