2004 Pontiac Aztek Gear shift light is out
JBKELLY73
Electrical problem
2004 Pontiac Aztek 6 cyl 129,00 miles
The light in my gear shift has gone out. Can this bulb be accessed and replaced?
Oct 19, 2010 at 8:47 AM
GMTECH
  • 537 POSTS
Your shifter has a replaceable bulb. It is a 194 bulb.
Remove the horseshoe clip on the back of the shift know with a small screwdriver, remove the two screws that hold the shifter plate and you should have access to the light.
Oct 23, 2010 at 5:06 PM
