2004 Pontiac Aztek
40,000 MILES • 6 CYL • FWD • AUTOMATIC
SPINARE12
dashlights do not work at night what is the problem
Sep 1, 2008 at 1:15 AM
  • 110,246 POSTS
Hi:
It could be something as simple as a wire lose under the dash. Make sure everything is tight. Also, it also could have something to do with the BCM. If you want, disconnect the battery for 5+ minutes and replace it. It may reset the BCM and the lights may work again. Keep in mind, if you disconnect the brattery you will loose all of your presets on the radio.
Let me know if this helps.
Dec 23, 2008 at 12:12 AM
