2003 Pontiac Aztek Vibration
2003 PONTIAC AZTEK
80,000 MILES • 6 CYL • FWD • AUTOMATIC
TAFFYLUVIN
There is a significant vibration when the front tires are rotating. What seems would be the tires, still vibrates when the tires are lifted off the ground. It is not the engine as the vibration does not occur when only RPM are increased. The wheel bearing, brakes, and side transmission bearings have been replaced. What else should I be looking at?
Jun 27, 2008 at 5:27 AM
  • 110,244 POSTS
Have you checked the CV joints or the axles? An axle could be bent or you could have a bad CV joint.
Dec 23, 2008 at 1:25 AM
