2003 Pontiac Aztek rpm
2003 PONTIAC AZTEK
MORRISTERRY8
Engine Performance problem
2003 Pontiac Aztek 6 cyl Two Wheel Drive Automatic
have a 05 Aztek and it has recently started idleing at 1500 in drive and 3000 in park. I have replaced the Throttle position sensor and that has not fixed the problem. Any suggestions that could help? Thanks in advance.
Sep 25, 2009 at 10:54 AM
LESLIEGOOLCHARAN
Check your manifold pressure sensor located atop the intake manifold. It is hooked up the the fuel pressure regulator via a t-conntector hose, so becareful and not pull it to get it off but rather use a screwdriver to pry it off. Also if any codes scan for them at local parts store.
Feb 2, 2013 at 2:43 AM
