2003 Pontiac Aztek not braking correctly
2003 PONTIAC AZTEK
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBERT OLIVER
my aztec anti lock brake turns on and i feel a vibration when the car is on the road, when pressure is applied to the brakes the left side skips and the car does not stop wheel keeps skipping disc and calipers are new could it be my bearing in the hub thats connected to the cv joint.
May 25, 2010 at 12:18 PM
  • 110,244 POSTS
Check the sensors to make sure they are not dirty. Also, check to make sure there are no wiring problems to the sensors.
Let me know what you find.
Jul 28, 2010 at 6:23 PM
VPEDWARDS
  • 10 POSTS
It may be the wheel hub, but I would think you'd hear a grinding/growling noise first. The hub is easy enough to change if you have access to metric wrenches and a gear puller.
If you need help contact me.
Oct 11, 2010 at 3:38 AM
