2003 Pontiac Aztek getting air in system
RANCORACIN42
  • 2003 PONTIAC AZTEK
Engine Cooling problem
2003 Pontiac Aztek 6 cyl Two Wheel Drive 75000 miles
has new pump, radiator, t'stat, been block tested, been pressure tested. Aztec has been to several dealers and independents, now it's my problem. I can bleed the system sometimes it will go 20-30 miles fine, sometimes it wont go 5 miles. I dont know if I'm not bleeding it right or is there a special way to bleed this vechicle.
Tuesday, January 6th, 2009 AT 10:49 AM
MASTERTECHTIM
  • 4,750 POSTS
There is no special way to bleed this system. I assume your having a overheating problem and I have seen lower intake gaskets cause several coolant problems along with in some cases a bad head gasket or cracked head, I would need more info to give more accurate info
Sunday, January 25th, 2009 AT 12:21 PM
