2003 Pontiac Aztek Gas
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
DON ARMENTROUT
Strong oder of gas, but no visible leaks and it does not appear to be using an abnormal amount of fuel
Dec 1, 2008 at 4:03 AM
JAMES W.
  • 2,394 POSTS
Check your fuel pressure regulator. there is a vacuum line attached to it. Pull the line off and look for fuel in the vac. line. If you, replace the regulator.
Dec 1, 2008 at 6:24 AM
