2003 Pontiac Aztek brakes
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANGELAGIVENS
I have a Question whenever i turn right and brake at the same time, i get a grinding noise and sometimes not able to stop without i guess bouncing to a stop. i have replaced my rotors and also brake pads on the front and also got a front alignment. it doesn't do that whenever i turn left or back up left or right just going forward and turing right and braking at the same time. what can i do to fix this problem i don't have a clue.
Jul 23, 2008 at 11:57 PM
  • 110,246 POSTS
Hi:
Check to make sure the backing plate isn't rubbing the rotor.
Let me know what you find.
PS: YOU ARE SURE THE BRAKES AND ROTORS ARE GOOD, CORRECT?
Dec 23, 2008 at 1:05 AM
