2003 Pontiac Aztek
73,000 MILES • 6 CYL • 2WD • AUTOMATIC
WAYNE BROOKS
rt.headlight is out. how do i replace bulb ?
Dec 20, 2008 at 1:01 AM
  • 110,248 POSTS
Hi:
The headlight can be replaced from under the hood. Locate the headlamp assembly and remove the plastic assembly that the wiring is going to. The bulb will be on the other side. Replace the bulb and reverse order.
Dec 22, 2008 at 11:11 PM
