2002 Pontiac Aztek noisey valves at start up
2002 PONTIAC AZTEK
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
ART CONEY
the lifters are noisy when I start the car for a couple of minutes, then quiets down. What should I do to repair it?
Dec 26, 2007 at 12:24 PM
BMRFIXIT
  • 19,053 POSTS
[quote:2c9be6cd21="art coney"]Engine problem
2002 Pontiac Aztek 6 cyl Two Wheel Drive Automatic 65000 miles
the lifters are noisy when I start the car for a couple of minutes, then quiets down. What should I do to repair it?[/quote:2c9be6cd21]
Try to use the correct oil
I think it ask for 5w30
the use of syntactic oil is plus
Jan 1, 2008 at 5:28 AM
TROY LEPPERT
  • 12 POSTS
There is a product called engine honey that is added when you change your oil that has a thicker consistancy and sticks to your upper motor parts so starts are easier on the motor
Sep 1, 2009 at 1:52 PM
