2002 Pontiac Aztek Noise in rear end
2002 PONTIAC AZTEK
92,795 MILES • 4 CYL • AWD • AUTOMATIC
PATTYOFAVON11
Hi When I turn right or left my back wheels make a whinning noise. We had the wheel bearing changed twice and the knuckle and we had a wheel alignment and new tires. what do you think this noise could be?
Aug 14, 2009 at 11:50 AM
SERVICE WRITER
  • 9,123 POSTS
Rear disc or drum?
Are you turning on blacktop?
Will it do it in reverse?
Aug 14, 2009 at 1:09 PM
PATTYOFAVON11
It does not do in reverse . And it does'nt matter what kind of pavement.
Aug 15, 2009 at 12:44 AM
SERVICE WRITER
  • 9,123 POSTS
Found a TSB for updated rear diff. fluid (PN 12378514). Drain and fill with new fluid, drive in a RH circle for 5 min. then drive in a LH circle for 5 min. then drain and fill again.
Aug 16, 2009 at 2:27 AM
