Heater problem
2002 Pontiac Aztek 6 cyl All Wheel Drive Automatic 130k miles
when I am not pressing on the gas pedel the heater starts to blow cold. Is there anything I can do to fix that.
Thursday, January 8th, 2009 AT 8:39 PM
IMPALASS
MECHANIC
Hello
Have you checked your coolant fluid level?
Also check the two heater hoses going into the firewall if your coolant level is okay and let me know if they are both hot or one is and one not.
Does the temp gauge also go down?
SPONSORED LINKS
Thursday, January 8th, 2009 AT 9:09 PM
BUGGMULLENS2
MEMBER
The gauge stayes the same but I will check the level and the hoses thanks.
Friday, January 9th, 2009 AT 4:05 PM
IMPALASS
MECHANIC
Hello
Make sure if you need to service it with coolant you do it at operating temperature (be careful removing the cap) and turn the heater on high to service.
