2001 Pontiac Aztek warnign lights
156,000 MILES • 6 CYL • 2WD • AUTOMATIC
ELBINSANGUILLEN
The "Anti Lock" and "Tack OFF" warning lights go on. The "Service Tack System" also lights up. They go off once the vehicle is turned off. They back on after a few miles of running.
Mar 12, 2010 at 5:45 AM
  • 110,246 POSTS
The lights indicate there is a code stored in the computer identifying the problem. If I had to guess, I would say there is a problem with one of the ABS sensors at the wheels. FYI, the two systems, ABS and Traction Control, work together. As a result, if one goes bad, the outher light will come on too.
Have the computer scanned to identify where the problem is coming from. Most nationally recognized parts stores will do it for free.
Apr 16, 2010 at 5:43 AM
