2001 Pontiac Aztek Transmission "slips"
103,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVEJUNK5
When in drive and starting out from a stop, I press on the accelerator, the engine revs, but the car doesn't move. Then, something "engages," and with a little bit of a jolt, the car starts moving. This seems to get better after driving the car for a little while. The transmission fluid level is checked and is fine (when car is running and warm). This problem has been slowly getting worse, and is now not engaging (sometimes) when moving and downshifting is needed due to acceleration. Ever since I've noticed the problem, I've been careful not to press the gas pedal too quickly, so that when whatever doesn't engage finally does, it doesn't slam in and jolt the car too badly.
Apr 23, 2010 at 12:51 AM
  • 31,937 POSTS
Hi there,
Time to get the transmission inspected by a trans specialist, this slipping and harsh engagement is constant with a very worn transmission, a test and report will give you a better picture of what you are up for as far as repairs are concerned.
mark (mhpautos)
Apr 23, 2010 at 1:27 AM
