2001 Pontiac Aztek timing chain or belt
2001 PONTIAC AZTEK
100,950 MILES • 6 CYL • FWD • AUTOMATIC
MWAL5
does a 2001 pontiac aztek have a timing chain or belt and if so, when should it be changed and what is the usual cost. Thanks
Jan 4, 2009 at 11:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle is equipped with a timing chain. Below are estimates for the labor and parts. Estimates will vary depending on repair locations as well as brand of parts used etc...
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_81.jpg
Most owner's manuals will suggest replacing timing chain every 150,000 - 200,000 miles. Hope this helps.. Thanks for using 2carpros.com !
Jan 4, 2009 at 11:23 AM
You have a timing chain - do you hear rattling/slapping noises within the timing chain cover if not keep driving
Jan 4, 2009 at 11:26 AM
