2001 Pontiac Aztek noise ,in front,,,also service engine so
90,000 MILES • 6 CYL • FWD • AUTOMATIC
CHRISTY MCHUGH
I have a noise in my right front wheel. I just had the brake pads changed and its still there. It starts out as a lite thump noise then it whistles, its very annoying, What did I miss
I also had my car checked for the light that comes on,They said it was a gas cap. but thats not it.
It seems when the car is parked on an incline , then i start it and put it in gear the light comes on, but if Its parked flat , I put it in gear and usually nothing happens.
I have seen a recal on the gas tank but it seems not to have those problems, no gas leak,
can you suggest?
Jun 13, 2009 at 6:20 AM
YTVERIC
hi there my name is eric! i have same problem like you! but i have a use obd2 code scaner got two erro code p0717 and p0716. in this few day i have to do a research on the internet some information about that two erro code.maybe you and me very lcuk! gm motor have ask recall to free replace part of the bad sensor when you got a erro code p0717 and p0716!next week i will make a phone call to gm
to confirm about recall!
Aug 19, 2009 at 5:08 PM
