2001 Pontiac Aztek Leaking Coolant
73,000 MILES • 6 CYL • 2WD • AUTOMATIC
DUNN419
I have 2001 Pontiac Aztec and it had a really bad coolant leak. So I put a new water pump on it and the leak as greatly reduced but there is still a bit of a leak. I can see coolant on the radiator directly in front of the belt, but I have no idea where it is coming from.
Jul 24, 2008 at 2:39 AM
  • 110,248 POSTS
Hi:
Most likely it's coming from one of the plastic tanks on the radiator where they are crimped to the core. You can have a dye test to be sure.
Dec 23, 2008 at 12:27 AM
