Engine Cooling problem
2001 Pontiac Aztek 6 cyl Front Wheel Drive Automatic 200k miles
So the history goes leak in the intake manifold and plugs misfiring. I replaced the intake gaskets, cleaned the rockers and rods, rebuilt the fuel injectors and replaced the following parts - plugs, wires, egr pipe (cracked) water pump, belt, thermostat. Drained and replaced oil and filter. Everything back together and started. Engine fired right up and I could smell gas noticed a fuel leak in the pressure regulater so I replaced. Filled coolant system with just water want to flush before adding coolant. Started engine no gas leak and it sounds good. I opened the bleeder on the bypass pipe and the thermostat housing to bleed the air. Drove the car about 5 miles and opened the hood and the engine was very hot smoking from below but I think its just hot. How do I verify the new water pump is working correctly?
Oct 14, 2008 at 1:52 PM
