2001 Pontiac Aztek BCM replacement
2001 PONTIAC AZTEK
89,000 MILES • 6 CYL • FWD • AUTOMATIC
TM4GOLF
Can you replace the body control module from one aztek to another. I know that it would have to be programmed for all of the functions on the new vehicle. But iis it possible to take one from a car recycling center and put it in another.
Oct 20, 2009 at 1:36 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes you can replace with a used module of same make / model vehicle but it will indeed need reprogrammed .
Oct 20, 2009 at 3:34 PM
JAZOOFARM
  • 5 POSTS
You CAN get one out of another Aztek, so long as it's got the same options and such. If you get one out of a "base model" Aztek and yours is "fully loaded," some of your options may not work. YOU CANNOT REPROGRAM these modules. I've replaced one in my wife's 2001 Aztek. Best option: Do a search online, buy a NEW ONE and take it to an auto repair shop you TRUST. They MUST "pull" the information from the old BCM to program the new, "blank" BCM. DO NOT buy a "refurbished" BCM. The auto shop I took mine to allowed me to remove my old BCM and install the new one for them to program. I spent $250 total for parts and programming. Most dealerships will charge $300 for the BCM plus labor to replace. Most independent shops around me will do the job start to finish for $500.
Apr 17, 2010 at 9:51 AM
