2001 Pontiac Aztek
14,000 MILES • 6 CYL • FWD • AUTOMATIC
CBIGBADMOMMA
My car was idling real fast and the gas cage was going crazy.. I put sea foam in it and the gas cage worked itself out then the idle worked itself out. I was told it was an idle control valve. Now it won't start. Could that keep it from starting?
Aug 22, 2010 at 12:24 PM
  • 110,248 POSTS
Yes, it could. However, it should have set the check engine light. Did that happen?
Sep 2, 2010 at 3:28 AM
