ket turned wont start lights come on tried other key still nothing gear shift u cant push butten in to get out of park help plaese going crazey
Feb 7, 2010 at 9:02 AM
✓Experienced Mechanic
Does the starter work? If not, have a helper turn the key to the start position while you check for power to the smaller wire on the starter. You should have 12+ volts.
