Turn signals on a 1994 Firebird
1994 PONTIAC 6000
CSPIVEY
1994 Pontiac Firebird mileage: 116000. My turn signals do not work. I have replaced the flasher relay, checked the bulbs, and the fuse is fine. I have run out of ideas so any suggestions would be useful.
Jun 11, 2006 at 11:01 AM
LSUSSEL
  • 252 POSTS
Do your hazards work? also known as 4 way flashers?
Jun 11, 2006 at 3:00 PM
CSPIVEY
The hazard lights work fine.
Jun 11, 2006 at 5:27 PM
DFX
  • 6 POSTS
You might try probing the flasher unit with a multimeter with turn signal on, this way you can isolate whether the malfunction is in the wiring down stream or the switch... Good Luck to you!
Jun 12, 2006 at 4:47 PM
