1991 Pontiac 6000 I have mo idea what's wrong with my car,
1991 PONTIAC 6000
113,467 MILES • 6 CYL • FWD • AUTOMATIC
THE GOOGLE
My car has been acting really weird, it starts than after I shut it off after driving 15, 20 miles it starts than acts like it's gna die, like it's runnin out of gas, then I put it in gear and it dies, and we check the fuel pressure and it has a lot of air in when we press down on the valve, than I get the air out and let it set for 5 or so minutes than it starts up and goes but still acts really weird, like it's running out of gas, we also put heet in the tank and it hasn't seemed to help, and the fuel pressure Was like 19 and it's supposed to be 40 or something, we changed the fuel filter and raised the fuel pressure to 23, 24, but it still dosent run right. Can you please help me?
Jun 3, 2010 at 9:31 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like you might have a bad fuel pump.What model do you have a LE or SE?What size is your engine 3.1,3.3,3,4,or a 3.8L.Let me know so i can help you out.
Jun 3, 2010 at 9:40 AM
THE GOOGLE
thats what us and other people we talk to think it is as well, but we dont wanna spend 100 bucks for a new one unless we know thats the problem, the Model is LE and the engine is a 3.1
Jun 3, 2010 at 12:15 PM
SATURNTECH9
  • 30,869 POSTS
Do you have a throttle body injection system or a port fuel injection system?Let me know.
Jun 3, 2010 at 12:34 PM
THE GOOGLE
It's a multi port
Jun 4, 2010 at 9:15 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1991_pontiac_6000_31L_fuel_pressure_regulator_test_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1991_pontiac_6000_31L_fuel_pressure_specs_1.jpg
Your fuel pressure is really low it's suppose to be 41-47psi i posted how to test your fuel pressure regulator and your fuel pressure spec's.Also if you have a dead blow hammer while the car is running and you have your fuel pressure gauge hooked up have someone watch the fuel pressure while you turn the hammer side way's and smack in the middle of the tank don't go crazy but give it a couple good smack's to see if the pressure goes up.Also check the vacuum to your fuel pressure regulator make sure it's good and you have manifold vacuum to it when the car is idling.Also while watching the fuel pressure at idle trying taping on the fuel pressure regulator and see if that change's the pressure any.Let me know what you find.
Jun 4, 2010 at 10:49 AM
